HVAC controls are backwards!
OBD II Readiness Monitors for smog
2004 fog lamps don’t work
The temp knob adjust the air flow. The vent knobs affect temperature. Like this when i bought the truck earlier this year. Possibly the wrong a/c controller? Fan knob only one works correctly.
Are the plugs the same for the regular system as they are for the dual zone? Could someone have downgraded when they replaced it? I don't know, just throwing ideas out. I'm sure someone here knows for sure.
I've replaced the a/c heater control switch. same problem! it is an SLT model. The door actuator doesn't move. The vent selector changes the heat/cool setting. I ordered the specific controller for my truck (expensive). Blower stopped working...but tapping on it with a screwdriver brought it back to life.
Bad motor likely as well as tapping gets worn or sticking brushes to contact again. Check the connectors at the blower motor for melting or corrosion. Same for the resistor pack. Then pull the resistor pack and check the ceramic resistor for cracking. Usually you replace both the motor and resistor pack at the same time as a stopped motor burns the resistor pack out. Another place to check is the ignition switch for melting connectors as the full motor current goes through the switch.
