Well basicly, I boned myself.
It started like this. I checked the operation of my truck's A/C earlier this year and noticed that my pressures were a bit lower than I expected. So I topped it off. Completely forgot to check my temperatures and just set the thing according to lowside pressure (temp). I wound up over-charging it by about 12 ozs. That's stupid manuever number one.
Well, knowing I did this, today I decided to trim the charge and get it back to operating normally. So I hooked up my gauges, connected my 50 lb. tank and started to trim the charge. Well, I went too far. So I added some back in. But wait, my temperatures and pressures were not corresponding to the behavior of R-134a. Low side was sorta right, but the high side was almost 350 psi!
I say to myself, "Self, what is going on here?" I look down and realized that I connected my R-22 recovery cylinder instead of my R-134a cylinder! AAARRRRRRRGGGGGHHHHH!!!!!!
I've contaminated about 30 pounds of R-22 with R-134a!!!
So I evacuate the system, completely! Then I recharge the system with virgin R-134a and check my temperatures and pressures. It works great. But now I've got all this screwed up refrigerant.
My question is this. I have a recovery unit (obviously) and a filtering unit. Is there any way I can separate these two refrigerants? I know they have different condensing temperatures and pressures. I know this can be done when you have a tank of refrigerant and it has a cap of air, but I don't know about refrigerants. Can I skim the 134a off the top (or bottom)? Or am I just screwed? Let me know what you think.
P. S. - I won't even go into detail on how I screwed up trimming the charge on my new central air unit tonight (works now). It just wasn't my day.
