Has anyone had any luck with getting a repair done on there 2006 truck when it was out of warranty even thou the problem was documented much early(7000 miles)This is an issue with aloud noise under the dash that I believe is related to the blend door in the HVAC system. Does anyone know if they have a TSB or recall related to the HVAC system on 2006 trucks. I have called Chrysler and I need as much info as I can get to plead my case.
Thanks,Mike
Thanks,Mike
