Just finished this job yesterday on my 2006 Mega. I knew I had a broken recirc door, but went ahead and pulled the whole HVAC system out and replaced blend and mode 1 doors as well (all HeaterTreater). Also cut out "the screen" on the top of the unit. All in all, MUCH better air flow and great instructions here.
A couple of thoughts while they're fresh:
1. The large dash bolts on my truck were 1/2". Everything else is either 10mm or 8mm. I would highly recommend having a regular socket, deep socket, and ratcheting box wrench in both 8mm and 10mm. A "stubby" socket driver is helpful. Also a cordless impact driver of some type will save the forearms. And a great work light, cordless fluorscent would be ideal. I still work with the old corded incandescent bulb and that little bugger gets hot and close when you're under the dash!
2. I drained almost 5 gallons from my radiator. Did not know it would be that much. A nice clean 5 gal bucket does nicely.
3. Once the dash is free, be GENTLE pulling it free. If it feels hung up on something it is! Probably either on a wire bundle you forgot to disconnect or a small PLASTIC piece that will snap under pressure. It's all plastic and will break (that's why you're doing this in the first place). Besides the radio wiring harnesses at the passenger side kick panel, don't forget to check all the aftermarket wires you have run to the dash! For me this included the trailer brake controller, the Jake brake, and the rear sliding window power switch!
4. The "order" of the original writeup is important. Don't skip around or you will be undoing and redoing.
5. The cab side of this job is pretty straight forward. I had most of my &*($ times under the hood. I had a helluva time disconnecting one of the spring-loaded connectors on my accumulator. 7 years connected and that thing did not want to disconnect. Even tried mild heat and penetrating oil. Don't know why it finally came off after several hours. My stubborn beat it's stubborn, but I didn't do anything different than I had done all along. Another note on the evaporator connections, they have a plastic safety lock that slides over the connection. It has plastic hooks on either side that need to be pulled back and locked out of the way before the lock slides off. Then use your disconnect tool (the donut) wrapped around the tube behind the fitting (firewall side of the fitting) and pull it towards the front of the truck to disconnect. There are only two of these fittings and they are different sizes.
6. At least on my truck, I had to remove the coolant overflow tank. (3) 8mm bolts, two on the firewall and one on the passenger side inner fender just behind the battery under a mess of wires. Also disconnect the rubber hose (pulls off). It was the only way I could get to one of the 10mm nuts that holds a threaded stud coming through the firewall from the HVAC system. I could have maybe got a wrench back there without removing the overflow tank, but the nut had sucked back into the rubber insulation on the firewall and I needed a straight shot at it.
7. A-Pillars: each one on my truck has two little oval tabs that you can pick open with a dental pick. This allows access to a 10mm bolt (deep socket)
8. Before you disconnect the battery: If you have power seats, make sure the driver seat is far enough forward to hold the steering wheel when that's lowered down.
-kuss
