Sounds like you are a bit overBOMBed. There has got to be a weak link somewhere. It looks like you've found it. That NV4500 is rated for 450ft-lbs, and how much stump pullin' torque are you running? 900 or so? DOUBLE the rated load, ouch!
Anyway, I have a Triumph TR-6 that is notorious for trashing throwout bearings. The mechanisim tends to stick which lets the throwout bearing slightly contact the pressure plate making a growling noise. The noise goes away when you push in the clutch. You never know!
