Engine/Transmission (1998.5 - 2002) hx-35 hybrid ?
im looking at gettin a different compressor housing and 60mm wheel from high tech turbo, (need to lower egts) just wondering if anybody else has this set-up and if they like it or not, and maybe who is competitive at pricing or other ideas you guys may have as long as there not to pricy
my truck is a 99 auto, with mods including edge juice, 4in strght pipe, ats manifold, 100hp edge jammer injectors, pusher pump, and AFE cold air intake. 4. 10 gears.
I have a similar set up with mach 2 and a hybrid turbo and 14cm2 WG. With just the 110HP sticks and juice on 1x1 I just barely run out of air onl the HX35/40 at 35psi during WOT. On 3x3 it smokes about as bad as the stock turbo, stock injectors and 5x5 at WOT.
I tow with it on 1x1 and have smoke on demand. I have a small s300 I am going to try out.
I have Industrial Injections 35/40 and can push 35 psi and I tow with it. I need to get bigger injectors to push it to 40 but it does OK. . I have a edge and bluechip with 4" exhaust and Bosch stage 2 injectors... you will read lower on the top end but you might read higher on the lower and cruise.
