HX-40, HX-35 turbine dimensions
Free flow muffler for '01 Ram?
Clutch Problem, Help!!!!
those of you with both turbos I need some measurements.
I need turbine blade OD and turbine hub diameter for both turbos so I can calculate effective flow area.
one more thing... I need the width of the housing outlet where the gas exits and enters the turbine for the HX-35 12, 14, and 16 cm^3 housings
