Engine/Transmission (1994 - 1998) HX35-40 Turbo Non wastegated
Engine/Transmission (1998.5 - 2002) Drag comp or ttufm
2nd Gen Non-Engine/Transmission Fog lights
Would this hybrid turbo be a good one for my mods? It is a 16cm non wastegate exhaust housing. Would a non wastegated housing be bad for everyday use?
Cal
Try and get a wastegated housing. You can actually flow more air out of a 14 cm housing (wg open) than a 16 cm (non-wg). You will start making topend heat with a non-wg housing. Plus with a wastegate you can control you boost and not run out of the map.
