If any of you is considering this swap but are wondering about the difficulty. Just go ahead and dive in. This has to have been the easiest bolt-on I've ever done for a major component. From start to finish (moving the truck onto a concrete work space till my tools were back in the box) took about 45 minutes! That was with me never having done one before. Knowing what size all the fasteners are, I figure you could probably do it around 30 minutes.
4) 15mm bolts manifold to turbo flange
2) 10mm bolts oil drain tube flange to turbo
2) 13mm bolts exhaust flange to turbo outlet elbow (lots of extensions)
3) 3/8" bolts? that hold the air box to the fender (didn't have to remove but seemed like it would give lots more room to move things)
2) 7/16" hose clamps from turbo to intercooler (deep well sockets)
2) flat blade screw driver hose clamps on air tube from filter to turbo inlet
1) 15/16" oil line nut that feeds turbo (line that comes from top of oil filter)
1) 3/4" adaptor fitting from oil line to turbo oil inlet
RESULTS---
EZ on middle setting
lost a little responsiveness with the HX. boost seemed to max out around 28 psi. EGTs maxed out around 1050 pre-turbo at around 105 mph. that is what I was really after. before 1200-1250 was no problem with the HY with no buckle. with the buckle it would do about 1150 and boost would have to be around 32 but it wasn't smooth, just a little accelerator change would have a huge impact on the boost. the HX seems very happy putting out 28.
I haven't towed yet so no info on that yet. Oh yeah you can hear the turbo more now too.
RESULTS---
