My HY35 wastegate is sticking shut and letting the truck build 30+ lbs of boost. Gets annoying when I have to down shift going up the hill to stop loosing speed and I have to let off or I will blow the intercooler boots off. I can get under the turbo and barley move the rod after the linkage is off. Can/Should I take the turbo off and remove the rear adapter to clean the soot out or is the bearing seized? I have a custom spring that would keep the boost around 27 lbs when the gate worked.
