I tried to use the 22 shell method, but the shell wasn't an exact fit for my hardline. By the time I got done filing the shell down, there wasn't much left of it - so I had to come up with something else.
I decided to use the turnbuckle method on mine (Like JR2 and the 22 shell, I came up with the turnbuckle method). If you are running 32# or less max. boost, you won't hurt anything by using this method. I think it goes on and comes off faster than any method out there. I can have it off is less than 30 seconds, once the wrench is in my hand. Only takes about 2 minutes to put on once you've done it a couple of times. Good luck!
Steve
