Hydro Formed Frame
Straight pipe legal in PA and NJ???
Should I ARBITRATE
I have read in a number of articles that the new Dodge Ram as well as other competitior's are manufacturing frame rails and/or cross members utilizing a hydro forming process. Does anyone know what this process is and the advantage to useing it?
thanks,
John
93 D350 LE CC, Auto, 65,000 miles, Stock, 94 11Z Elkhorn Camper
Hydro-form, and its many variations, has the advantage of forming a given material with a more uniform contact to the dies. In conventional dies, pan brake, pressbrake, stamping etc. the stress area is "concentrated" in a small area inviting fractures and other failures. Bathtubs and those hollow brass doorknobs are hydro formed, water or a hydralic fluid forces the material to conform to the die set. I am not sure how hydro will be used in frame fabication, however there are many variations of the method. Frames are, IMO, overdue for a better manufacturing process. It seems technology has somewhat passed them by.
9535hundred
[This message has been edited by Statland (edited 04-15-2001). ]
Hydro-forming simply means using a hydraulic fluid to help form tube metal. GM has been using this for some time in the C5 Corvette, as well as the new P/U's. A tube of steel is capped on each end and pumped full of a hydraulic fluid which is pressurized. This internal pressure helps form the tube steel to the die, giving uniform bends in appearance and strength. I was suprised to see Dodge was going to this manufacturing process, but all manufacturer's probably will use more of it in the future.
Randy Jones, San Antonio, TX, rdj@gvtc.com, 98 1/2 QC, 4X4, American Racing BAJA's, 285/75/16, Amsoil throughout, Superstar 3000 export radio, Firestik antenna with fender mount, Fire-ring cable, Mag-Hytec Deep transmission pan
2000 VW Jetta TDI, auto, 45 mpg average
