Well I did it. I drilled and tapped a hole in the exhaust manifold for the pyrometer.
It was actually really easy. I did the axle grease on the drill bit/tap routine and used a small magnet to get any metal that escaped the drill bit and tap.
I had to run the tap much deeper than I thought I would. I actually got concerned because the thermocouple still would not start in the hole after several turns of the tap in the hole.
So I grabbed a 1/4" piece of mild steel, drilled a hole in it and tapped it for the thermocouple. This gave me some ideal how far the tap would have to go.
So a word of advice. If you have never used an NPT tap, practice on a piece of steel first.
Only thing left now is the Auto trans temp sender. I have the brass "T" and compression fittings. Probably attack that this weekend.
Bobby
2000, Driftwood, 2500, automatic, 3. 54, 2WD, LWB, SLT, Quad Cab, most of the options, Grover air horns, tow 5500lb 28'x8' Aerolite TT and two small boys.
Bobby
