First off i did my first oil change, in the past i had the dealer do it
can someone recommend a good oil filter wrench to use?
when i finished the oil change and let the truck run for a bit to let the oil flow so i could check it i noticed that there was a little bit on top of the filter, i hand tightened the filter and then turned it a littlt tighter with my oil filter wrench Any suggestions?
Third I just rolled over to 140,000 miles and am still stock my first mods are going to be gauges Egt,Boost,Trans Temp.
How hard is it to install gauges and when you buy gauges do they come with everything you need to install them.
A friend of mine remover his silencer ring from his turbo what does this do?, does it just give a little more whine?
I hope i am not boring you with the basic questions but i have been sitting back for a while and trying to learn about my truck from the forums.
Thanks in advance
Thanks in advance
