Bob4x4 said:
If either pump fails it will become a BIG restriction and you will have less flow than either pump on its own .
Bob
Bob... do you know that for a fact? What do we know about that in-tank pump? Who makes it... . what kind of pump is it... has it been used in gasser applications or is this something designed for diesel fuel only... . if it stops (fails) does it become a restriction or will the VP suck fuel through it???
This info may have been posted already (I've been on the road for awhile) but I don't know squat about this pump.
I did gripe to the dealer that installed mine. They weren't happy with the fuel pressures either but apparently DC is. Here's a little update on my pump with about 5K miles on it.
It's seems very sensitive to fuel system conditions. I just changed out the fuel filter and picked up about 1 to 1 1/2 psi. Cold fuel brings the pressure down noticably. Once the engine (and fuel) warms up the pressure moves up a little. I'm sure this is normal to all pumps but when you're only starting out with 5 psi you tend to stare at the guage on cold mornings.
On the plus side. . the engine starts, idles and runs just fine (wow... isn't that what a Cummins engine is supposed to do??).
If I keep the truck I'm leaving everything as is until it runs out of warranty and then the old LP will go back on to run in series with the tank pump. If I sell this rig I'll never own anything with a VP44 injector pump..... period. HPCR is the way to go anyway.
For now our winter trips to Mexico will stay very close to the border. I'm really worried about getting too far from a repair facility that carries VP44's and can swap them out. A pusher pump ,FASS or something would certainly help matters... . but I have no faith in the VP44. Some fail mechanically, some electrically. Some fail with good fuel pressure. . all fail with poor pressure. The thing is just fragile. If you noticed... Cummins didn't stay with it too long.
I think the 2nd generation 24v Cummins is a beast of an engine. It has one problem and one problem only... and everyone here knows it... the VP will fail without notice.
Mike
