hotram03 said:Will this make you feel like you can stop?
Well I finally revisited this while doing an axle-ectomy. (long story)I decided to forgo the fitting fiasco and go direct. I cut into the main line going to the ABS valve and re-used the threaded fitting that connects to the flex line to the axle. I then double flared the main line and plumbed it into the flex. DONE! Now the ABS valve is ballast.
