The Bridgestones are doing great. When I rolled in from yet another haul on Friday, it was time for another oil change, fuel filters, and tire rotation. I got home around 8:15 pm and at least knocked out the oil change (nothing like pulling the oil drain plug after the engine has been going for about 8 hours) :-laf This morning....I'll knock out the fuel filters and tire rotation. Upon checking my records, it looks the RD500 HD's have 43,561 miles on'em. Extremely pleased with them.......
Don't have a Facebook account....and I don't have a Fumoto. I guess I'm still a caveman :-lafC'mon you haven't installed Fumoto Valve?
Everything that I have that Fumoto Makes a valve for form Lawn mowers to Shop Air compressors.
I know of Owners with 2013s 6.7 with 400k Miles on Factory Emissions just the fuel stuff being freshen up and some Water pumps belts minor stuff, Proper maintenance and habits and I'm sure some will break 500k miles. I've had owners call Me at 80-100K miles wanting to delete BC of emission failures (Understandable But We don't do them ), Driving habits have a big part in longevity.
I received P0868---Transmission Fluid Pressure Low. If you recall the contour of the transmission pan (deeper towards the front---shallower towards the rear....for what I assume is to accommodate the sump filter) I can only surmise that the extra quart or so of transmission fluid that's left in the pan during a typical drain & fill keeps the transmission "primed". Dropping the pan and subsequently removing the sump filter will therefore allow the transmission to lose prime, then throw the P0868. I can't verify this to be true, but knowing what my code was, along with a hunch, it's the best answer I can give ya!!!Greg, I just did my second transmission service and for the first time I got the mil. Just like you it slammed forward and reverse. It actually put the truck into limp mode with only 4th gear and reverse available. I couldn't even manually select 1st or 2nd. I shut the truck off and restarted and the limp mode disappeared and several start cycles later the mil shut off. Do you know what code the transmission throws after a filter change? I'm going to check for a stored code with my buddy's snap on Solus when I get a chance but I'm curious as to which code and why.
The Bridgestones are doing great. Upon checking my records, it looks the RD500 HD's have 43,561 miles on'em. Extremely pleased with them.......
Your front axle is several inches lower than the valve.
I use a smaller plastic pail that 3" diameter chlorine tablets are shipped in. :-laf It holds all the oil, and, like your milk pail, does not splash when I pull the plug....even after about 8 hours of engine run time.I personally don't trust people so I won't use the Fumoto. I have zero issues with splashing using my trusty Milk Pail.
No argument there, but as much time that I spend off road and stuff I've both seen and done I wouldn't use one either. It probably would never get damaged but not having one means I don't have to worry about it either. It all depends on the truck usage and your own level of paranoia. :-laf
