What would happen if I cut the wire for the lock up and put in a push button switch? I guess what I'm wondering is if I do this #1 when the switch is made it should be as stock right? #2 when the switch is open will the converter be unlocked or locked? What I'm after is when I'm towing and come to a hill and the RPM's get to low I would like to be able to unlock the converter with out dropping out of OD, motor on over the hill then lock the converter back. I don't have an engine brake or do want to lock the converter for harder acceleration, I just want to keep my RPM's in that sweet spot when towing, I guess I'm more concerned about unlocking it instead of locking it, thanks, Chris... ... .....
