Engine/Transmission (1998.5 - 2002) I love my SB Con O but...
2nd Gen Non-Engine/Transmission rear wheel seal
Engine/Transmission (1994 - 1998) turbine housing & pyro tapping
Truck: 2001 HO, Van Aaken, Bosch 300HP injectors (RV 275's) and straight piped. Pusher pump on the way, 7 PSI WOT.
The clutch is wonderful, smooth but no slippage. So here is the problem: I have a TST PowerMax sitting on the shelf, been tested by PowerMax and works fine, just needs the remote control. I cant find a vaccine for the HP bug.
Will this combo be too much for a Con O?
I'm just looking for opinions from others who have experience with the Con O.
there's only one way to find out ;) im about to ditch my Con FE for a southbend double..... i cant find a vaccine for the HP bug either... . i got bit a long time ago by the bomb bug, and its still infected. :-laf
but seriously, i believe the Con O is rated around 350hp?? has your truck been dyno'd? you outta be okay IMHO.
I'd bet it would be fine, as long as you don't tow the rediculous weights some guys do. I have seen the 5-speed Con O stand up to 505rwhp in a daily driver with no towing.
