i need some more testing as i only had the 20 mile drive home that got interrupted by a lovely traffic jam that screwed up the last 10 miles, but even then it didn't cycle it got up to 200 slowly and stayed there at 70 mph, and when i was idling in traffic it dropped a couple needle widths below 200 and pretty much stayed there till i got back up to speed at which point it returned to 200. i recently installed a new t-stat (truck didn't have one when i bought it) from the dodge store that came in a cummins box with a august 05 date on the label, i was annoyed to discover it gave me the 1/3 to 2/3s and back swing of the temp gauge that seems to be somewhat common here, on the bmws and volvos i work on everyday this would be death, this evening i pulled the t-stat and looked at the design of it and the housing and decided the t-stat was too isolated from the flow of coolant through the bypass and overreacts, i drilled a couple small holes in the inner part of the t-stat so it would get some flow so it wouldn't get shocked by the temp so much and slam open and closed, i've been drilling holes in thermostats for years to help in bleeding the systems of contrary/complex air pocket prone euro cars, i guess the little hose that bypasses the t-stat to allow the system to burp works too well
