Well well well. I finally gathered the cojones to drillo my manifold and move the pyro to the PRE turbo location. I tapped it on the 4-5-6 cylinder part of the manifold, and about 1/2" from the turbo flange. I have been told this is almost ideal.
I also didn't tap the hole all the way down. This is to prevent the tip of the probe from touching the manifold (bottoming out). When I pulled the probe out, the soot line ran almost all the way up, so I figured my probe was a little too far into the hole.
Anyway, onto the results. YIKES! The response is TOTALLY different. The pyro needle moves and moves fast now! Cruise EGT is only difference by about 200°F. BUT, transient EGT is VERY different. Yeah, I could almost never hit 800° post before. PRE, I can see 1400° if I stay into it!
So the "rule of thumb" of 200 degrees difference between locations is a myth. I have personally seen as high as SIX HUNDRED DEGREES of a difference.
I am convinced that the only way I would see high EGT in the POST-turbo location is if I stayed into it long enough to really hurt something. By then, the damage is done! What's the point of having a pyro if it doesn't give you warning?
I just used the grease-and-magnets method that everyone seems to use. It turned out just fine.
Don't be afraid like I was. Go PRE-turbo and do it right!
Justin
Justin
