I have a 2004 5.9 Laramie HD. I bought it used with 260k. Over the past 2 years, I have put a total of 13k on it. I had to replace the alternator, both batteries, and the starter. I had a problem at the beginning of July with the pass battery. It overheated and popped the cap leaking acid across the top of the battery but nowhere else. I got it replaced. Almost exactly one month later and the pass battery did it again. Lost volt gauge/reading no volts. I take it to Orielly's to have them test the charging system and the battery has popped its top again. They send me to Walmart, where I got the battery. Make it 2.5 miles away from O'rielly's to Walmart, and the cap has blown off the battery spraying acid all over the interior passenger engine compartment and the crossover wire is smoking. Walmart refuses to honor the warranty and sends me on my way. I get the battery out of my Grand Cherokee (750 CCA, as opposed to the 850 CCA, recommended for my truck) to replace, temporarily, the passenger side battery to make it 6.5 miles to home. Truck starts right up but I have no volts reading. I make it home. A friend of mine comes the next morning and installs an external voltage regulator and new gold Raptor terminals on the batteries. He arcs the driver's side twice while installing. Try to start the truck and it does fine. He goes about his day and I try to drive my truck. I have a somewhat bumpy driveway and truck dies before making it to the road. Just dead, like no current. I think I might have run it out of fuel so the same friend brings me 5 gallons of diesel. Try to start it, no gauges sweep and truck just cranks but won't start. He starts moving wires at the fuse panel, moving the steering wheel and tilt with no luck. He checks all fuses and presses them all down tightly. Truck keys on and gauges sweep and truck fires right up. We both leave believing the problem was a loose fuse. I make it 5 blocks from my house with my 2 boys in the truck and it cuts off again like no current, just dead. Have it towed home and start messing with the wires because the only common occurrence between the two deaths is truck went over a bump. My husband reroutes the main ground/positive fusible link to relieve the stress on it having been stretched across the driver's battery and the truck starts up. He drives it hard, over bumps/curbs, guns it, revs the engine, slams on the brakes and the truck does not die! Since this, replaced the main ground on driver's side and the truck started and ran then the same friend went to put the top back on the fuse panel, and the truck died again. Also replaced the fusible link that goes into the same housing. Checked all fuses. Moved around all the relays. Bypassed the crossover cable. I have run all the tests I can without a diagnostic reader. I did the ODO test and it reads A4, AA, AC, AF. It has not done a gauge sweep so I know it won't start. I am at the end of my rope with this. I really need some help.
