Engine/Transmission (1998.5 - 2002) I need injectors.. help
Engine/Transmission (1998.5 - 2002) fuel box only???
my 98 24v with kn filter, EZ and 4" exhaust wants more power. I have the 5sp manual and want a good set of injectors that will work well with this application.
any help appreciated
are you going to change the turbo? what is your goal for power? if you just want a bit more and want it as inexpensive as possible, check out some Rv275 injectors. if you want better injectors, go for a set of Mach2 (+/-) injectors from www.f1diesel.com (several dealers are members/advertisers here, choose your favorite). at some point I would get rid of the K&N (assuming it is a replacement element) for two reasons: 1) oiled element will tend to let some oil residue into your intake tube and turbo compressor, and 2) K&Ns flow well for their size, but they let a lot more dirt through to accomplish this flow.
My final note, keep the stock HX35 turbo wastegated to ~35psi or less. Anything more than that is just excess heat and less power
SamBrown said:
my 98 24v with kn filter, EZ and 4" exhaust wants more power. I have the 5sp manual and want a good set of injectors that will work well with this application. any help appreciated
As mentioned above Formula 1 injectors are the apex of the injector world. If you want give us a call and we can discuss the different options available.
Doug
