I Need Rear Mud Flaps
Ball Joint Pains
Console Thermometer
I have a 2004. 5 short bed single rear wheel with xenon wheel flares and wheel well liners ,anyone know where I can get a set of soft not preformed rear mud flaps that will fit (inside the wheel wells) without damaging the xenon flares. Anyone know what size I need for the rear single wheel config? I'm damageing my trailer by throwen rock's,Thanks :confused:
I have not seen any you can purchase that install inside the wheel well. here is an idea, Get some 1. 5" square tube that can slide into the sides of the trailer hitch and mount rubber mudflaps onto the tube. When towing you just stick them into the hitch. Your going to have to figure out a way to hold the tubes into the hitch. YOu could drill and tap a hole in the hitch that you tighten a bolt down onto the mud flap tube (might weaken the hitch?) or maybe put a bolt into both tubes with the mud flaps attached to them, then run a bungy cord between the 2 bolts to hold tubes into hitch.
I do something like this for my slidin camper rear hold downs, only I drilled a 1/4" hole all the way through the hitch and inner tube that I put a pin through. My inner tubes extend out past the sides of the truck for the camper holddowns.
I have a set in my Reader Rig's Gallery. The rear are 14" and the fronts are 12". I now have flares and used the original holes for the mud flaps I'll take pic to night if need be.
BLACK PEARL said:
I have a set in my Reader Rig's Gallery. The rear are 14" and the fronts are 12". I now have flares and used the oraingal holes for the mud flaps I'll take pic to night if need be.
BLACK PEARL,
Cool looking flaps where did you acquire them?? :confused: :D
I bought the Mud Flaps from Action Accessories. Here is the Link
If you don't like the flames they have others.
The nicest set I have seen Is IN Geno's and guess what
They don't sell them. They are on page 22 down at the bottom under Stainless steel fender trim molding. I called Geno's and wanted to order a pair and they said they did not sell them. Wish they did. Maybe If all you would call or e-mail them about they might think about It. I like those and would look sharp on my truck. This Is my winter truck to drive here In the mountains. I need to go and get a another load of firewood. Its getting cold here now.
My mudflaps are 14" wide. I had to cut them down a bit at the top to make them fit inside the wheel liners. They are Air Hawk mudflaps. A family member made the Cummins decal. Check out the picks in my gallery
Thanks Pearl, nice looking mudflaps!!
