I need tuning help! (I think?)
Turbo noise on throttle backoff or trans shift
smarty smoke
Please help me figure out what I do or don't need to do. With all the mods in my sig. Smarty= 60 HP Moderate Torque, most recent programing. TST= 2/2.
My EGT's climb faster than my boost gauge(40-50psi), and don't stop until I let off the go pedal. I thought my high dollar turbo was supposed to keep my EGT's in check.
What gives?
Please, your suggestions would be a great help.
Well, it seems as if you're auto trans is already running on borrowed time... but that aside, here's what I'd try:
Try running Smarty up higher, like on #8, and back the torque number on TST down some. You can maybe run #9 aftermarket injector/aftermarket turbo program to lessen the timing just a bit, if you don't get too much audible timing rattle when supplementing with TST.
Running #8 or #9 on the Smarty, set the TST around 2/0 for starters. Setting the TST on 3/1 produces more power on the dyno, but will drain the rail on the road, and thus cause higher temperatures.
If you're running #2 Torque on the TST for the low end power, try bumping up the Smarty to wild, and lowering torque on the TST. This seems to be smoother power, less smoke, and keeps temps lower as well. However, your transmission is the weak link here.
Also, if you can run a Beta 4. 4 program, it will eliminate the temporary dip in rail pressure when getting on the throttle, and will help keep rail pressure up.
I have a pretty similar setup as you do (except I'm adding the TS MP-8 for a little pressure), and I made 554 hp/ 994 tq running Smarty 4. 4 beta, Tst 3/1, and TS MP-8 100%. On the road, temps will peak at about 1350°. Dropping the TST to 2/0 peaks at around 1250°.
One more thing, if you want to risk the stock head bolts, or plan on studding, run the boost up a little higher, to maybe 55 psi or so. That's a big turbo you've got, and 55 psi should be well within it's efficiency range (at least according to my drive pressure gauge).
Hope that helps some... --Eric
p. s. As a disclaimer, I wouldn't really try what I suggested until you bottom tap and stud, get a built transmission, and address the freeze plug blow-out issue. And even then, no gaurantees... :)
I agree with most of the above. Set TST torque to 0. I run normally with Smarty #4 or #6 and TST timing default 12* Auto and hp/tq set at 2/0. I do always have a little added pressure with my EZ on level 1. With the current released Smarty versions my EGTs are a higher than I like also.
But hopefully the lastest Smarty version that I am testing will be released very soon. It is not a beta 4. x version, it is a normal release level code for Aftermarket Turbo, Stock Injectors and Mild TM. This version has dramatically dropped my EGTs across the board and up to 250* on high end WOT.
