I need your part numbers
Boken detent on d/s towing mirror
Cab Lights Install
I am in the process of getting part numbers togeather for our trucks. If you have any part numbers I would love to get them so I can make a decent list. Things I have so far include
upgraded fuel filter part number 68001914ab
newly designed clearence light, Dodge part number 5507559AD
07 Pac brake: There is one switch, 4602692AB ($9). There are four possible bezels depending on what equipment you have, brake, heated seat, and power slide window.
1FB13DX9AA Brake only
1FB14DX9AA HS-Brake
1FB15DX9AA PSW-Brake
1FB16DX9AA HS-PSW-Brake ($12)
fuel rail relief valve 5093113AA for 2003
fuel control actuator 5183245AA. If your dealer tried to order the pump it would have given him a GPOP tech tip stating that the FCA was available.
Cummins: Part # is 4932457, description; actuator, ETR fuel control $103. 63 W/Washington sales tax
Steering Wheel Controls: I got my parts 10% over dealer cost.
The Harness Part # 56042934AA List $24. 50 (I paid $16. 17)OR 56000918AC
Left Switch Part # 4685728 AB List $14. 10 (I paid $9. 30)
Right Switch 4685729 AB List $16. 45 (I paid $10. 84)
Cup holder light 55361226aa
Underhood light 56021441 wiring harness is 56051115-AA
If we could get a few more of the more common parts would be great. Even if you could add a price that would be great too! I have them in a word doc and would like to make a nice complete list Thanks
I think that's a good idea! In fact, I have been keeping some miscellaneous part numbers in a spreadsheet for future reference. Here's what I have accumulated from different posts here...
From Auto Parts Fast at RockAuto
Front driveshaft ujoint Precision 295
U-joints, front axle, outers, axle shafts AAM 9. 25 Precision 464
Rear driveshaft U-joint for Man. trans trucks, greasable Precision 351
From the Dodge Dealer
Moparfuel tank skidplate 52121265 AB SHIELD 23-034-121
Dodge factory under tailgate light for '07s 55277299aa
front pinion seal 5086697AB
Heavy duty rubber splash guards, front 82207118
Heavy duty rubber splash guards, rear 82207702
Mass Air Flow Sensor 53032649-aa
Inner Fan Shroud 55056985-aa
Radiator Hose 52028872-ad
Radiator Hose 52028873-ac
Charge Air To Turbo Hose 55056560-ab
Charge Air Duct Clamp 55056561-aa
Fan Shroud Outer 55056980-aa
Fan Shroud Bracket 5139068-aa
Fan Shroud Bracket 5139069-aa
Fan Shroud Bracket 5139067-aa
Power Steering Pump 52113925-al
Charge Air Duct Clamp 52028977-aa
Fan 52028878-ab
Fan Clutch 55056990-ab
Alternator 56028732-aa
AC Compressor R5055339-ah
Motor Mount (QTY 2) 52021136-aa
Rubber Mount (QTY 2) 52122714-ab
From Cummins
Jacobs exhaust brake vacuum pump 3965925
PTO ground pin for high idle clutch switch bypass 3824810
Fuel Control Actuator (FCA) 4932457
Other
Hub bearing assembly, rbattelle BR930502 SKF, or Napa
thermostat, much better quality 375-190 Napa
Thanks for your willingness in putting this together! --Eric
Dhuffman, is there a differance between short and long bed?? I have been thinking about getting them for my longbed.
Yes, there is a difference. I think the price is the same, but the rear flares are different. I'm not sure what the part number for the long bed is.
I really like these flares. Easy install, and they look great.
Power Wagon Flares
Power Wagon Flares for Long Bed... part number is 82209353.
here is a current list of parts that I have so far... .
Misc. numbers
6 Spd. U Joint part numbers... .
Rear driveshaft 2 Piece precision (takes 3) greaseable Precision #351
Front driveshaft Cardan H joint (takes 2) greaseable Precision #232
Front driveshaft @ front axle (takes 1) greaseable Precision #235
Front Axle U joints LEFT AND RIGHT (takes 2) greaseable Precision #464
Rear Axle, 2WD w/ Auto. w/3 Joint Shaft PRECISION # 330
Center Bearing, 2WD w/5 Spd. Man. Trans. PRECISION # 330
Rear Shaft at Center Bearing, 4WD; w/3 Joint Shaft Exc. 6 Spd. PRECISION # 295
Rear Sway bar (summit) 7651 Hellwig
Hub bearing assembly, BR930502 SKF, or Napa
Dodge Dealer
Engine
Clamp, Charge Air Duct 52028977-aa Or 55056561-aa
Clutch Switch Kit, for high idle in manual transmission 05+ trucks 05175417AA
(Clutch Switch Kit, Cummins 408985100)
Fan 52028878-ab
Fan Shroud, inner 55056985-aa
Fuel filter, upgraded 68001914ab
Rear main seal 5114027AA
Exterior
Fender Flares, Power wagon (shortbed) 82209352, (longbed) 82209353
skidplate, Fuel tank 52121265 AB SHIELD 23-034-121
splash guards heavy duty rubber, front 82207118
splash guards heavy duty rubber, rear 82207702
Towing mirrors with turn signal, power and heated 82209293 ($475)
Wheel well liners (rear only) 82207367
Front End
Pinion seal, Front 5086697AB
Interior
Dash bezel, Laraime Silver in color, 5GV531L5AC ($274. 00!!)
Fuel-Operated Cabin Heater (dealer add on for 06 made by espar) 82209444AB ($1300)
Instrument dash light bulbs SC4839738AA (. 70 ea)
Push Button Start, SRT-10 switch 05029463-AA
Push button start, SRT-10 Dash with hole YM11XZA-AA ($250)
Pac brake, 2007: There is one switch, 4602692AB ($9). There are four possible bezels
1FB14DX9AA HS-Brake
Harness Part # 56042934AA $150, OR 56000918AC $40
Lights
Cab clearance new design 5507559AD
Tailgate, under the tailgate for '07s 55277299aa
Underhood light 56021441 wiring harness 56051115-AA
Fog lamp package # 82208102
headlight switch for foglamps #560455378AC
jumper for the fog lamps #56045501AC
Cummins
Clutch Switch Kit, for high idle in manual transmission 05+ trucks 408985100 (mopar 05175417AA)
