I have had my truck almost a year now and I have filled the tank exactly 40 times. Every tiime, I have filled it to the top of the fill neck to get the extra 3-4 gallons in. this amounts to about 50-65 miles of extra range. I regularly get between 570-620 miles to a tank. I like to keep accurate mileage records as well.
The price I pay for this is that I have to spend an extra 5-7 minutes at the pump slowly trickling the last few gallons in. If I averaged 6 min per fill, in 40 tankfulls, I spent an extra 4 hours at the pumps this year. Some of it in bitter cold and with other people waiting for the pump.
NO MORE!!
I ran the truck to where the D. T. E. read 0 and ran the truck another 30 miles. I pulled the tank and still had about 3" of fuel on the bottom of the tank. It was obvious why the tank filled so slow. The aft end of the tank is about three inches higher than the main vent for the tank. This, combined with the rear of the truck sitting higher than the front made it difficult to get fuel in the raised part of the tank.
This pic shows the height difference of the rear of the tank compared to the vent tube (the smaller of the two hoses)
After I pulled the tank, I spent about 4 hours running around looking for all the fittings and hoses I would need. After I got everything, I took the plunge and drilled a hole in the highest part of the rear of the tank with a hole saw. I used an empty plastic tub to catch all of the shavings inside the tank. Access to the inside of the tank is easy because of the location of the fuel pickup and sending unit.
Here's a pic of the relationship between the hole for the sending unit and the rear of the tank.
This is the fuel pickup and sending unit. You can see the float for measuring fuel level.
Here's where I mounted the vent:
Next, I removed the fill neck and cut the vent tube and inserted a brass "T" in it's place. NOTE: This is NOT required with the new vent kit in the classifieds!
Here's a pic of the whole system out of the truck The only piece missing is a section of vent tube for the main vent.
I raised the tank back up into the truck and made all of the connections. Here's the finished vent connection:
NOTE: The finished vent connection with the classifieds kit looks different than this pic. There is no need to cut the metal vent line. Just install the included brass "T" fitting in the rubber hose.
I went to fuel the truck and it worked like a charm! It filled right to the top and clicked off. It took about 10-15 SECONDS of slow filling to top off with fuel in the fill neck. No standing by the pump waiting anymore!!
Oo.
NO MORE!!
Oo.
