After extensively researching as many threads as possible concerning lift pumps I suspect that many have been needlessly replaced.
The LP is an electric motor driven pump. This means that it's output is not directly affected by engine speed. It is affected only by the flow on the output side. Flow on the output side is affected by the amount of suction created by the injection pump as it adjusts to load and throttle settings.
At idle the injection pump places minimum demand on the LP. To limit the amount of pressure that the LP can develop I am lead to believe there is a pressure relief valve that is set at 14 PSI. As the throttle is applied the injection pump requires more fuel. I am also lead to believe that the injection pump pulls suction on its inlet to the extent that the LP pump is almost not needed. This causes the pressure drop on the outlet side of the LP pump.
The question that should be asked of Cummins or Bosch is what pressure if any is required on the inlet side of the injection pump. If the pump truly can operate without an LP then I would expect the answer to be a negative PSI (or vacuum). At some point it is possible that the LP actually might inhibit the flow required by the demand on the injection pump. This condition probably never occurs on a stock engine but most likely occurs when you bomb the engine requiring greater fuel flows than stock.
The LP actually is working hardest at idle because that is when the injection pump would be creating minimum suction at its inlet, thus creating maximum pressure on the outlet side of the LP pump. That is why the Dodge Service Manual only calls for checking the LP pump at engine idle. That is when it is actually working the hardest. While a good new pump should be putting out 14 PSI I assume that there is eventual wear in the pump so Dodge has set 10 psi as the minimum allowable pressure at idle.
Sometimes a little extra knowledge is not good unless the knowledge is understood. Most owners do not have FP gauges and drive around ignorant of fuel pressure. Then they go out and install one and right away go into a panic over readings that they do not fully understand. Instinct would indicate that pressure should increase with engine speed just like oil pressure. But that is not the case here.
