I'll give you guys my experience over the last few years (now that I'm thinking about it, it's more like 4 years) with my truck. I removed the stock lift pump with 36k miles on it and put in a Mallory 4140 (140gph) fuel pump back by the tank. I wired it to a relay that was switched by the stock fuel pump wires. I ran -6am lines from the pump to the filter and then on to the injection pump. About every 6 months, I would burn the brushes out of my pump, and would have to rebuild it. Not a big deal, other than a diesel bath and 15. 00 on brushes. I kept a spare set in the glovebox after the first one went out. Did this scenario for a couple of years.
Then I was in the mountains of North Carolina late at night on the way to Knoxville for vacation 2 summers ago and it went out on me. I didn't have a spare due to the parts store screwing up the order and not getting any in before I left. I ended up pulling the guts out of my pump and using the injection pump to suck fuel through the housing, made it to my destination fine, and picked up another set of brushes the next day and rebuilt the pump in the hotel parking lot.
I have had this happen twice more, and performed the same until I could pull the pump and rebuild it. I can pull the guts out without removing the pump.
I had a relay go bad on me about a year ago, and didn't have a spare one, so I just routed power to the pump (I already had a kill switch in the cab of the truck to break the circuit). Since that time I have not had to rebuild the fuel pump and it is still putting out a steady 12psi at idle.
The truck currently has 190,000+ official miles on it as of last week, still running the stock injection pump. Here is my synopsis, the truck can run fine without the fuel pump, but it must be obstruction free. I had to pull the guts out of my pump in order for the truck to run (but that is the design of my pump, it's a gerator style, so flow when off is almost nil).
Second the powering of the pump or switching it on by the computer controlled wires may be another culprit of the pumps lack of longevity. If I rmember right, the comptuer cycles the pump in some way to ensure proper fueling pressures. I just get in the truck flip the fuel pump on and crank it. No hard starts, no problems.
I am still running the same Mallory Fuel pump I bought sometime in 2001. I bought a second one, but ruined it out here in SC due to getting into some deep saltwater one night downtown when the water levels were real high.
Morph.
