RRR, that is EXACTLY what I found on my 99 recently. I had about 90K on mine when I did it. I had several of the intakes 016-. 020" though. I set mine at . 007" and . 020" and noticed that I gained a noticeable amount of low end torque and the overall throttle response is a lot better. I think the optimal setting from what I have read is . 010" and . 023". As far as I know I ran mine with excessive lash for a long time, it really wont hurt anything so you can run it till the wekend no problem. Adjust them when you get a little time and you will like the results.
BTW, took me well under an hour to adjust too, about 40 minutes if I remember right.
