thats funny, bet he didnt like that. like harvey said you are not dumb naive or misinformed, you simply did not know nothing wrong with that. harvey is also correct about why inline 6's are used most often, they have i think it is 40% fewer moving parts thats less to go wrong. in trucks they are a little easier to overhaul and with fewer parts definatly cheaper. also they tend to get better fuel mileage while still providing big power for pulling.
however harvey v8's are not ONLY for fords and chevy's, cummins was a few years ago working on v6 and v8 engines for the dakota and 1500 sized trucks, they may have pulled the plug on that by now though. there are heavy duty applications with v8's and even v12's, the 3408 was used in many heavy haul trucks in the 80's i think, cause it could build big power cheaply and reliably, the compitetion at the time was the cummins kta and ktta, they were i6's and had massive power, and the best jakes on the market, however they cost a lot more than a 3408 to overhaul, and were higher maintence, and the cat could go the distance, i think it was new better technology in inlines with more power and better fuel mileage that phased them out. same with the detroit 2 strokes, in their day they had the best power to weight ratio and many were v engines, even pancake engines, the ranged in size from 4 up to 16 or 20 cylinders with a displacement of 53 to somewhere around 102 cu inches per cylinder. they could be found all over the world in trucks, pumps, mining, drilling, power gen and many others. i know in dozers and large excavators they ran v engines, typically 8 or 12 cylinder. most power gen engines are v's and a lot of mining and drilling equipment have v engines, as well as marine.
the main reason why inline 6's are used so much is they produce big power on minimal fuel, its an effecient design, however i would argue about reliability, that boils down to maintenece period, cat and cummins are not going to build big bore v configured engines as throw aways especially when they are in marine applications. maintenence is key, i will agree with you though that inline 6's are probably cheaper to maintain then v8's. also the b series cummins aka the 5. 9 and now 6. 7 are throw away engines. all engines that are parent bore block (cylinder liners cant be replaced) are considerd throw away, so before you go bashing on ford and chevy keep that in mind.
