nascar mark said:Unfortunately you had the problem of your fuel filter messing things up at the time. If your engine still needs some pedal effert to fire up, try turning out 1 click now that your filter problem has been fixed.![]()
JGrover,
I just rethought your last post. Do you mean you backed the gov retainer nut up 1 turn or is your final adjustment only 1 click in? If only 1 click total in, I would rethink this as you are living dangerously. Generally the best setting is inital click plus 2 = approx . 050" from top of gov stud to top of retainer nut... tighter means more than . 050" with a "pro" of faster fuel ramp up, with most times a "con" of higher than normal idle (adjustable) and having to push the go pedal to start engine. Your choice (live with it or turn out 1 click for slower fuel ramp but no pedal effert starts... . 1 click equals . 017" ).
JGrover,
