Engine/Transmission (1998.5 - 2002) Idle fine no power above that
Engine/Transmission (1998.5 - 2002) uneven rpm when cold
Engine/Transmission (1998.5 - 2002) Possible transmission Issues
1998 24 Valve 2500 stock that idles fine and no:confused: power after that . Autozone checked for trouble code and it said Throttle position sensor. Is that the same thing as my1985 TPS and could cause the lack of power?
Thanks for your Time and Help.
I had that happen with mine and found that it was the APPS. I forgot to plug it back in after I had done some work. It started and idled fine but the pedal did nothing.
Check the plug to see if it is inserted all the way.
