I have a 1991 non-intercooled, five speed, fuel screw turned in, cone ground, timing advanced, 3200 governor spring. Before I installed the governor spring I could put the truck in first gear and idle up my steep driveway. It was almost impossible to stall the truck. After installing the spring the idle is sometimes high and sometimes so low that it dies. Now if I let the clutch out with no throttle on flat ground the truck stalls. Other than the idle and no low end torque the truck runs fine. Has anyone experienced this or have any ideas on how to fix it? Help would be much appreciated, thank you.
