"Mad Max"
Peeps,
Does anyone else notice an idle rpm drop when the engine is good and warmed up? Most of my usual commuting is around town, 15 minute drives to work and back, etc. But this week I was towing the 28-footer and everything was well up to temp - engine/transmission both at ~180*, and when up to temp the idle seems to drop just a bit; add the A/C and it wants to lug. I end up placing in neutral and everything is fine, but I wondered if there is an engine management thing that is not working properly or if this is normal?
Obviously my idle setting is a bit too low - a slight nudge of the pedal and the rpm comes up just a hair back to my 'comfortable' range, and of course a slight idle screw twist and it'll be fine, BUT, why not when it's cold, and why when it's hot?
Tweaking the idle will increase the idle, but is there a bigger issue causing the problem? Thoughts from the congregation??
Muchas grassyas,
- M2
Muchas grassyas,
- M2
