Turbo Tim 1
OK, I looked through the history a little bit but it seemed every time someone had a similar symptom they never posted what the fix was. My 2001 has a skip at idle after it is warmed up, usually the first time I drive it for the day it is fine, if I shut it down after it is up to temperature for 5-10 minutes and then start it back up it has a skip. Also it is definantly worse on hot days. There are no codes showing up, the fuel pressure is running 15 psi at idle and 10 psi on WOT, I replaced the cam position sensor but the didn't fix it. How about some brilliant educated been there done that answers to my problem. The truck is bone stock and has 40,000 miles on it. Thank you in advance
