hey folks I was working on the service truck today found #1 delivery valve on the pump a lil loose & leaking fuel I thought this would clear up a slight miss (or weak cylinder) at idle which seems to come & go I dident have time to adjust the valves but I did pull #1 rocker cover & the exhaust valve I easily slid a . 025 feeler guage under so if I have time tomorrow Ill get t them adjusted & see if it idles better it pulls like hell & seems to run well otherwise the miss is subtle the truck sat a long time before I got it & Ive only put like 50 miles on it since I wonder if one of the injectors is a lil flakey or varnished? I tried to do a cylinder balance test by cracking the injector lines open to kill each cylinder but the miss is so subtle that it was hard to tell which cylender was weak
Ill start with the valves I know they are WAY out
any ideas on the matter would be appreciated thanks again
JAK
JAK
