yes marco is right , i was just about to post that .
also on injectors , when you did the test how did it sound between cylinders when you cycled the injectors ? i had a problem like that with 275's , 2 bad cylinders , they sounded very different than the others . i took the injectors to the bosch shop i got them from , when they tested them by the BOOK they were within spec , but when they cracked them slowly , much like idling , there were two that were marginal , i never told them which , but i numbered the injectors and the 2 bad ones were the bad cylinders that were found when ted j. ran the test for me .
