Ignition; key culinder vandalized,
First Gen HX35W Sputtering Issues?
Explain the KDP details to me...
They tried to steel my Dodge I guess, and damaged ignition (key cylinder?); cannot insert the key, seems nothing else is damaged: My question: how difficult (expensive fix would be)?, how parts (lock assemble, I guess) is available, as last resort - to do manual wiring and disable column lock?
any advise, idea welcomed,- included pick of lock area, noting else is damaged, broken
thank you in advance.
If you can’t get the key in the standard removal technique won’t work..You can drill out.the damaged cylinder.
