Replaced my left side ball joints today. Read the threads and had a good idea of what I was getting into. Took off the axle nut, loosened the 4 12pt bolts half way and put the puller on the hub. Started out with my 1//2" drive ratchet on the puller, a little turn and the assembly starts coming off
I'm so happy that its going so good, I forget to take the 4 12pt bolts out the rest of the way
I keep turning the puller thinking I'll be done in no time. POP off the hub comes. Well, half of it anyhow. I greased up the bearing good and pressed it back togther. The rest of the job went real well. Started at 8:30 and was done by noon, including a parts run for a upper ball joint (I was just gonna do the lower). Hopefully the bearing is ok, only time will tell.
STUPID HURTS
Chris
STUPID HURTS
Chris
