Just a thought to all you guys considering gassers because they are low maintenance compared to the bigger trucks. It must have been awhile since you drove one because typically there is an ignition coil for each spark plug now. And those spark plugs should be replaced every 25-35k. And they are not the 2-3 dollar plugs of yore. I put plugs in my wife's old 02 chevy. Iridium tipped to the tune of 11 dollars a piece. For the pep boys brand! And the fuel filters should also be replaced around 25k. But they are not exactly accessible or designed for easy replacement so tearing the fitting off the line is possible. And no, the threads aren't NPT, or aeronautical. They are some wierd one off type.
Don't forget those fun catalytics either. and the rotten exhaust pipes from the water that comes from the cat. Factory SS pipes would make the truck too expensive.
Just wanted to send you a little reminder about the wonderful world of gas.
I do have a hot deal on an 02 2500 Chevy HD if you are determined to get one though.
