I got your pm as well but, I figured any info or insight I can give is much better to be seen by more people in the event they ever have a similar problem.
I am not going to lecture but, next time you have any troubles ever, no matter what they are please do what you can to pull the exact codes. We can take these codes and symptoms and really put a better finger on any issue you might have. Without the actualy codes we can only make guesses even if they are educated guesses. In this instance they are not as important to know whether or not the fuel pressure sensor was the issue but, it might be important to know them so we can figure out if the problem was or could have been fixed with a reflash.
Now I am assuming that the only modification is the Commander at this point.
The only way that I can think that there is even an outside chance that the fuel pressure sending unit could cause the truck to die would be if it was leaking and allowed air in the system. I do not think this happened and I doubt that it would have taken more than a few minutes for the problem to show up.
The fuel pressure sending unit itself is simply measuring the pressure at the inlet of the CP3 pump. We use a tapped banjo bolt so flow is not affected even 1%.
Now there is a possibility that the Commander had an issue although it would something I have never heard of and it is sort of far fetched but, I think it could be possible. With that said, I would think you would know if you had a problem with the Commander that would have caused this. In order to do this there would have to have been some sort of serious voltage problem or short somewhere in the Commander that might have done something stupid to the temp or boost pressure sensor. I think you would continue to have problems with the Commander after this happened and I think you would have noticed this on the Commander itself.
Now I personally do not feel this would or could happen even though I think it is possible. I jsut hate to say never.
There are only a couple of ways to get the truck to shut off like you mentioned. The first would be a fuel problem where the pump turned off or was not running. This is also a little far fetched as I know that these trucks will run with no lift pump and the CP3 can actually draw the fuel if it has to although the performance would be poor. If you hit some sort of limp mode for some reason it could also do something similar.
If yo uhave the codes please post them up as we can really look at specific areas to see if it is possible the Commander did something.
Also, even if it was a Commander problem I cannot possibly see how it would be with the fuel pressure kit in any way shape or form unless it had a leak which is almost impossible with npt fittings.
The XZT can be used with the Commander, with the Fuel pressure kit or all by itself. The XZT is 100% stand alone and does not require any other parts to function. Now if you do add it to the Commander you can set de-fueling parameters to automatically adjust the module to keep you from hitting these warnings. The most common use of this would be de-fueling by EGT. If you hook the fuel pressure kit up you can then de-fuel based on Rail Pressure and/or Lift Pump pressure.
Last thing. I made some posts about some problems we have had with the fuel pressure sending units on various sites and frankly I can hardly keep up with all of them! In short, we know the issue and are replacing sensors. This problem is not associated with dying trucks but, less than stellar accuracy on the lower end of the pressure sensor.
For the full story read it here:
http://www.dieseltruckresource.com/dev/showthread.php?t=134503
Please give me any more info if you can and if you have any other questions please ask!
Quad
Quad
