IM LOST!!!! Please help me out.
High elevation issues
Which chip for a stock 2007?
As anyone with an 03 cummins with a NV4500 probably already knows finding a clutch will drive you to insanity. I have found a clutch that I may buy but I dont know if it will work. Since my pickup has the NV4500 five speed I am having a hard time finding one. Most of the clutches for the 45 are up the the year 02. Will an 02 nv4500 clutch work on an 03 year model? The clutch Im looking at is the NMU70119-04 by valair.
$474. 32 12. 25" x 1. 25" Performance
Replacement Ceramic Buttons
HD Spring Hub
Rated @ 550HP / 1000 ft lbs Torque
3800# Pressure Plate
Kit includes: Pressure Plate, Clutch
Disc, Release Bearing, Pilot Bearing
and Alignment Tool.
Call Peter at South Bend Clutch 800. 988. 4345 and he will be able to tell you exactly what you need and ship it to you. Nobody knows clutches for these trucks better than Peter.
Godspeed,
Trent
I just had a customer in with a Valair disc... . ceramic/kevlar..... and he'd mildly turned up the HP and the disc failed in 15K miles... . his disc was build like an automotive or light truck disc with marcell in the disc and those light steel fingers fractured and broke off... . we don't do performance clutches, just stock units... so I referred the customer to South Bend...
