What about using after market clear lenses that are for non sport models. I have found them at autopartswarehouse.com want to know if someone has done that instead of the fitting of the sport headlights in I was just wondering?
I think the below link is what you may be looking for. Certainly a LOT cheaper. I installed this kit on my truck and it made a noticable improvement.
APC Headlight Conversion Wiring Harness Kits: AMC-509104 - summitracing.com
Your problem will be gone if you perform the fogs-on-with-high beams modification shown at the bottom of this page: http://dodgeram.org/tech/mods/electric/headlight.htm. . . However, it created another problem. If you are running factory fog lamps it screws with your high beams. If your fog lights are on and you hit the high beams, no problem. When you flip the switch to go back to low beams, the fog lights come on and the high beams STAY ON! The only way you can get back to low beams is to kill the fog lights. Only then will you get back to the low beams. . .
Hey check out LMC Truck. They have a catalog for the 94-06 models. catalog page Cover
Just ordered the Euro Headlight set for my '02 along with the Heavy-Duty Headlight Harness. Hopefully this will brighten things up a bit. Should have them installed in about two weeks. I will let you know how they work.
Wow Gary. Thats looks like a tight squeeze![]()
Anyone have experience with sport lights from Headlight Depot via ebay? OEM replacements complete with halogen bulbs for $179. Thanks
