Thanks everyone for pitching in here with suggestions!!!
At the suggestions of Robert, AEdelheit, and others, this is the plan...
The stock rear springs are ~ 52" eye-to-eye, and are comprised of 8 leaves 3/8" thick. This spring is sitting on top of a 4" block stacked with a 2" block to give 6" of lift. Obviously, this is not a great setup. Spring rate is approximately 647 lb/in.
I already have some Skyjacker CR33S springs from an '88 - 92 Chevy Suburban. These measure ~ 63" eye-to-eye, and are comprised of 5 leaves 3/8" thick. I'm doing a shackle flip with an 8" shackle. This will allow a full 6" of lift with no blocks. Obviously, the front and rear hangers will need to be relocated. Plans for this are from Offroad Exchange for those interested. These springs have a rate of ~ 257 lb/in, and offer an incredible 20" of rear suspension travel!!
In the front, I'm having Alcan make a custom front spring, somewhere on the order of 350 lb/in. Alcan Spring - Manufactures Fine Custom Leaf Springs These springs will allow 6" of lift, and I'll run 1/2" longer shackles to allow the springs to come to life and work as they should. These custom springs run about $235 each if anyone's interested.
I spoke with Don Thuren today (thanks taking the time to talk with me!!!!) from Thuren Fabrications. . : THUREN FABRICATION - HOME :. I think I'm going to run Bilstein 7100 smooth body remote reservoirs in the rear, valved at 360/50. In the front, I'll be running Bistein 7100 smooth body remote reservoirs valved at 360/80.
I chose this setup for several reasons. First, I already had the CR33s rear springs. Second, I'm running Bilstein 9100s on my '06, and they're incredible... but pricey. The goal for this truck is to have a fun 350 hp comfortable daily driver that can do everything well, but nothing great
. I'm building an '87 Dodge that will be the real offroad machine, and the '06 is already setup to tow more than should be allowed. The '91. 5 will be the all around, do a little of everything truck. Finally, I don't have a huge budget for this truck... and going this route can be done for ~$1300.
With the above spring/shock combination and shackle flip on the '91. 5, I should have 12" front travel and 20" rear travel that will offer an incredible ride for daily driving, and allow 1000 lbs of tongue weight without sagging too much. The Bilstein 7100s should ride great, and allow some moderate flogging offroad when the situation arises.
As a side note, I've found the Bilstein 7100 remote reservoir shocks to be the best bang for the buck there is. They are completely rebuildable, and every seal and hard part can be purchased separately at very reasonable cost. They are one of the only shocks that you can select different valving profiles for without paying for a custom setup. They have a schraeder valve to charge with Nitrogen, and the remote reservoir and oil capacity allows them to be pushed ALOT harder than a normal emulsion shock... and at a price of $185/each, they don't require you to re-finance the house :-laf This company eshocks.com: Off-Road Shocks: Bilstein 7100 Series Shocks offers good prices and free shipping as well.
I'm probably going to fab some custom brackets and run a Bilstein 5100 series stabilizer (or two) for steering control.
I'll update with photos and feedback as things start to come together...
Thanks again!
--Eric
Thanks again!
--Eric
