In Tank Pump
MAF sensor Engine shut Down???
Trans stuff...
just a note, i did the in tank conversion on my 03 and it showed a world of difference. before with my bd pusher and (new)filter mounted lift i could still pull below 5psi with edge and tst, now does not even come close to that low no matter how much pressure, duration i throw at it.
You probably could have bypassed the factory lift pump and gotten the same results. When the factory pump goes tu that 15psi carter will have a hard time pushing through.
Bob
