inchpounds????
Hose clamps
transplant: does anybody know if......
if you don't have an inchpound torque wrench can you divide the number of inchpounds by 12 to come up with the corresponding foot pounds to torque bolts down? chris
chris sutton
1999 2500 qcab longbed 4x4 red sport w/ all the options 'cept plow pkg, 4:10 detroit locker in rear & waiting for ARB front,
5" skyjacker lift w/ 35" BFG mud terrains on 16. 5x9. 75 Weld rims, black nerf bars, black bug persuader, lumber rack,
camel leather int. w/ mb quartz spkrs and 8" sub & coming soon DTT t/c & vb, mag hy-tec transmission pan, red magview pig covers,
275 injectors & power edge EZ, guages
If the inch pounds torque needed is above something like 150 it should work fine. I would be leery of trying to do something under 100 inch pounds with a ft. pound wrench because of accuracy. bg
BG--thanks--I also did a search and found out the same ---thanks again ---chris
chris sutton
Yes that's correct. Remember that to make sure you are getting an accurate ready, you need to stay between 20% min and 80% max of the range of the wrench:ie to torque to 80 pounds (either ft or in) you need at least a 100 pound wrench respectively. In the same example you need to torque to a min of 20 pounds.
98. 5 3500 SLT Quad Dually 4x4. 3:54 Auto, Waterfall Blk on red. Custom dually flaps, All acc's w/leather
BD exhaust brake, dash mount Banks guages, Mag-Hytec Diff. cover & trans. , SS bug screen and fender trim,SS Stull diamond line running boards, SS 4" turn down.
Justbeam, I learn something new everyday. Thank you very much. Maybe one of these days they will be selling digital torque wrenches and you can just set them for inches or feet.
1999 Qcab 4x4 Driftwood
Steve
I bought an inch lb torque wrench at Pep Boys for around $25. Decided not to risk converting ft lb wrench with small measurement. Worked great.
Wiredawg
[This message has been edited by Wiredawg (edited 02-05-2001). ]
