Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Engine/Transmission (1994 - 1998) Increase pwr on 96
Engine/Transmission (1994 - 1998) temp gauge sensor?
I woiuld like to increase pwr on 96 with AT about 50 HP. What plate and timing would be best. TBOB This is for a friend.
I own a 96 CTD with the TAG, stage one AFE pro guard 7 and 4in turbo back. I got a little turbo whirr when I put the TAG in. Would I benefit from taking the silencer ring out, if yes -how would that make a difference. Your response is appreciated.
David
omfg... . i popped out my silencer ring about half an hour ago, and took the ole rig out for a spin..... i dont think i ever had a bigger grin on my face... . deffintley take out the turbo silencer
The truck would really feel good with a gov spring kit.
A little more timing and a 6-8 plate.
Soon you will need trans work and then it would be twin turbo's and the 370 injectors.
It never stops!!!!!!!!!!!
BTW, your mileage will go up IF you drive it easy.
