I had the trans line recall done this morning just as many others have but after browsing the earlier thread regarding this topic it seemed vague as to what exactly is replaced and why so I figured I would start a new thread for those who will be having this TSB done in the near future.
The line in question is the short one that comes from the transmission and goes to the heat exchanger that's mounted to the engine. Apparently under extreme duty, vibrations emitted from the trans travel through the rigid line and can crack the heat exchanger/cooler.
However, (here's why I resurrected this) the crack is internal, meaning no fluid will leak onto the ground. Instead, you have cross contamination of ATF in the cooling system and antifreeze in the transmission. This of course is disastrous for the transmission. The new line has a rubber hose in the middle to dampen any vibrations and takes no time to install.
One thing I did read in the other thread that I found interesting is that the dealer has the ability to check the "duty life" of the engine through the pcm. If the duty life exceed's certain parameters then the cooler will be replace regardless of a leak or not.
Hope this helps
Rosco
Hope this helps
Rosco
