I've worked on several of the Cummins engines in different Air Force equipment and was not even aware of the 53 block issue until I found this sight. The AF equipment is serviced regularly and not run hard around the flight line. We had just a few 24 valve equipped vehicles come in to are shop before I retired.
Now I have all this information and keep bouncing back and forth trying to decide which generation to buy. Knowing my luck it looks like no matter if it is 1st or 2nd generation truck I'll end up getting one that the engine will end up cracking. So from what I under stand the 2001 year the last of the 53 blocks ?
What can I look at for ball park repair cost of replacing or repairing a cracked 53 block ? Also is there less chances of having a problem between a manual or automatic transmission with the 53 block ? This truck with any luck at all will be my last purchase. I'm 68 yrs old and have got 335,000 on my Chevy 6. 2 that this Dodge will be replacing. I will not be adding any power parts to the truck as I'm only going to be pulling a 22ft or smaller camp trailer and a 16ft car trailer with it, and just getting a 4x4 one because of the snow we get so most of the use will be on the highway.
Guess I'll just bite the bullet and get a 1st or 2nd generation 4x4 manual trans with as few of miles I can find and hope for the best.
I thanks you all for your help and advice with my truck decision.
George
